When I debug/step via BDT I have for example this output:
[07:54:48]:
pause mcu, pc : 0x01445e
00000000 <__start>:
10: 3363742d tcmpncc r3, #754974720 ; 0x2d000000
00000220 <__irq>:
222: 64ff tpush {r0, r1, r2, r3, r4, r5, r6, r7}
00000220 <__irq>:
224: 6bd8 tmrss r0
00000220 <__irq>:
226: 0641 tmov r1, r8
00000220 <__irq>:
228: 064a tmov r2, r9
00000220 <__irq>:
So, for example in tpush {r0, r1, r2, r3, r4, r5, r6, r7}, is it possible to see what values in r0, r1... r7 are?
Is there a document describing all assembly instructions for example like above tcmpncc, tpush, tmrss and others?
HI,
At present, this part of the information is not publicly available.
So how can you debug the firmware?
To be honest, I don't want to know assembly instructions if I could debug in C. But I can't - so the only option is to understand how assmebly works.
In BDT, the nly thing you can do is to read/write variable values or memory. In most cases it will be sufficient.
If you try to use BDT debug/step through instructions you see the assembler instructions but Telink doesn t provide information about them.
You provide precompiled libraries, no source code - and the assembly looks like as shown in my first post. How can you debug this?
You didn t answer whether it is possible to see what r0 ... r7 in the example tpush {r0, r1, r2, r3, r4, r5, r6, r7} are? Or in tmov r1, r8?
I can guess that tpush will push variables on the stack - or not?
And tmov will move value in r8 to r1. But others who knows?
But what is r8 or r1?
You can t debug in C, you can t debug in assembly. You can only hope that the code work.
It s like the issue I have had for half a year which I described in another thread. I can t fix it and Telink couldn t fix it.
