I am trying to connect to TLSR8258 CS5460A (energy/power IC) via SPI.
I had a look at the SPI example in the Driver SDK and in the spi.c code, but I don t think this is going to work.
The code in spi.c read function is like this:
/***write cmd***/
for (i = 0; i < CmdLen; i++) {
reg_spi_data = Cmd[i];
while(reg_spi_ctrl& FLD_SPI_BUSY); //wait writing finished
reg_spi_ctrl |=FLD_SPI_DATA_OUT_DIS;
/***when the read_bit was set 1,you can read 0x800008 to take eight clock cycle***/
reg_spi_ctrl |= FLD_SPI_RD; //enable read,0x09-bit3 : 0 for read ,1 for write
temp = reg_spi_data; //first byte isn t useful data,only take 8 clock cycle
while(reg_spi_ctrl &FLD_SPI_BUSY ); //wait reading finished
/***read data***/
for (i = 0; i < DataLen; i++) {
if(i==(DataLen-1)){
reg_spi_ctrl &= ~FLD_SPI_RD;
Data[i] = reg_spi_data; //take 8 clock cycles
while(reg_spi_ctrl & FLD_SPI_BUSY ); //wait reading finished
What is required for CS5460A to read is while reading data from the SDO at the same time sending byte 0xFE.
This is from the datasheet of CS5460A:
During the read cycle, the SYNC0 command
(NOP) should be strobed on the SDI port while
clocking the data from the SDO port.
SYNC0 command is byte 0xFE
How can I clock out 0xFE byte on device SDI port, while reading data from device SDO port?
As you can see from "write cmd" and "read data" above, reg_spi_data is used for both writing and reading? So how can I write and read at the same time?
This is from the SPI protocol definition:
During each SPI clock cycle, full-duplex transmission of a single bit
occurs. The main sends a bit on the MOSI line while the sub sends a bit
on the MISO line, and then each reads their corresponding incoming bit.
This sequence is maintained even when only one-directional data transfer
is intended.
From the TLSR8258 datasheet:
The TLSR8258 embeds SPI (Serial Peripheral interface), which could act as Master mode or Slave mode. SPI is a high-speed, full-duplex and synchronous communication bus requiring 4 bus lines including a chip select (CS) line, a data input (DI) line, a data output (DO) line and a clock (CK) line.
But then:
Address 0x09 bit[2] is the disabling bit for SPI Master output. When the bit is cleared, MCU writes data into address 0x08, then the SPI_DO pin outputs the data bit by bit during the 8 clock cycles generated by the SPI_CK pin. When the bit is set to 1b’1, SPI_DO output is disabled.
Address 0x09 bit[3] is the enabling bit for SPI Master reading data function. When the bit is set to 1b’1, MCU reads the data from address 0x08, then the input data from the SPI_DI pin is shifted into address 0x08 during the 8 clock cycles generated by the SPI_CK pin. When the bit is cleared, SPI Master reading function is disabled.
It seems that there is only one data register 0x08 (in/out)
From this part in the data sheet:MCU reads the data from address 0x08, then the input data from the SPI_DI pin is shifted into address 0x08 that it would be possible but how to do it?
- Would I have to remove from the read function this line that disables data out -
- and then write:
reg_spi_data = 0xFE; //send 0xFE byte
- ... what to do here to get data in?
- do I write
- and then
data_in = reg_spi_data; //to read data
Will data_in have received data?
The description in this datasheet section has been modified to half-duplex http://wiki.telink-semi.cn/wiki/chip-series/TLSR825x-Series/, and currently only the 9 series supports full duplex spi.
So it doesn't comply with the SPI protocol specification.
I wasted 2 days trying to get it to work, What a disappointment that it took 4 years to find that out and update datasheet - 2022!
What is this in the latest datasheet?
Reading this - MCU reads the data from address 0x08, - I understand that MCU sends data out from address 0x08?
I wonder whether it Is the limitation of the chip or limitation of the library?
The read and write of this register cannot be performed simultaneously, which is a limitation of the chip hardware.
Since hardware SPI doesn't support full SPI protocol (full duplex), I have decided to implement "software SPI". Using sleep_us(10) to create clock pulse I have full duplex SPI working.
