I have a device that sends the status message which is configured as below:
epInfo_t dstEpInfo;
memset((u8 *)&dstEpInfo, 0, sizeof(epInfo_t));
dstEpInfo.dstAddrMode = APS_SHORT_DSTADDR_WITHEP;
dstEpInfo.dstEp = 1;
dstEpInfo.dstAddr.shortAddr = NWK_BROADCAST_ROUTER_COORDINATOR; //0xFFFC;
dstEpInfo.profileId = HA_PROFILE_ID;
zoneStatusChangeNoti_t statusChangeNotification;
statusChangeNotification.zoneStatus |= ZONE_STATUS_BIT_ALARM1;
statusChangeNotification.extStatus = 0;
statusChangeNotification.zoneId = g_zcl_iasZoneAttrs.zoneId;
statusChangeNotification.delay = g_zcl_iasZoneAttrs.zoneDelay;
zcl_iasZone_statusChangeNotificationCmd(1, &dstEpInfo, TRUE, &statusChangeNotification);
Destination address is set dstAddr.shortAddr = NWK_BROADCAST_ROUTER_COORDINATOR., I understand that the message was supposed to be send to all routers and coordinator.
The gateway receives the message but not the router device! Both devices have the same EP.
What am I missing?
Is there any code that I should put in the router device to receive this message?
have you ever added the IAS Cluster in Router's sampleLight_inClusterList[] table,our default table has not this Cluster ,you can reference gatway to implement it.
Yes, I have it:
const zcl_specClusterInfo_t g_AppClusterList[] = {
#ifdef ZCL_IAS_ZONE
{ZCL_CLUSTER_SS_IAS_ZONE, MANUFACTURER_CODE_NONE, ZCL_IASZONE_ATTR_NUM, iasZone_attrTbl, zcl_iasZone_register, App_iasZoneCb},
#endif
And in zcl_appCB.c I have a function:
status_t App_iasZoneCb (zclIncomingAddrInfo_t *pAddrInfo, u8 cmdId, void *cmdPayload) {
led_toggle(LED7);
I added a led to see if there is any message coming but there is nothing.
try toggle LED in void zcl_cmdHandler(void *pCmd),if zcl pack recived ,this function will be called,and then find why the application not process it.normolly ,should run in status = pCluster->cmdHandlerFunc(&inMsg);
Issue solved.
The problem was with the code to toggle the led.
I had:
if(0 == drv_gpio_read(GPIO_PD2) ){
drv_gpio_write(GPIO_PD2, 1);
else{
drv_gpio_write(GPIO_PD2, 0);
drv_gpio_read(GPIO_PD2) always returned 0. It looks like, drv_gpio_read(GPIO_PD2) only works on inputs?
Since there is no gpio toggle function in drv_gpio.c, I had to go back to gpio.h, and use function gpio_toggle(GPIO_PD2)
