As I wrote above, in the SDK documentation there is:
Volatile u16 T_debug_except_code = 0;
static void sampleLightSysException(void){
T_debug_except_code = T_evtExcept[1];
while(1)//or SYSTEM_RESET();
But this doesn t compile because T_evtExcept is not defined - it is a local variable in function u8 sys_exceptionPost(u16 line, u8 evt) (in ev.c).
In this function, it calls g_sysExceptCallbak(); which doesn t have any parameters. So how is the T_evtExcept[] transfered in the g_sysExceptCallbak()?
3、if call SYSTEM_RESET() ,the information will lose,so modify SYSTEM_RESET() to while(1) or some else. 4、use extern or you can modify the call back structuer of typedef void (*sys_exception_cb_t)(void);
1. This is in the file that is part of the SDK. If I modify it, I will have to remember when the SDK is updated - like I did in many other files. It is hard to keep track of the changes!
4. That's what I did before I saw your post. But it is the same as point #1 - I modify the SDK file for one project, so it will affect all other examples in the app folder - callback function in other examples won't have extra parameters.
The reboot casuse reason may you Called SYSTEM_RESET() or PC point run to wrong place,you can try search SYSTEM_RESET in SDK and add some logs.
Thanks Soyo,
There is not a lot of information in the SDK documentation.
What I found is, that I can use T_evtExcept[]:
In the ev.c file I found:
volatile u16 T_evtExcept[4] = {0};
T_evtExcept[0] = line;
T_evtExcept[1] = evt;
/* TODO: some information stored in NV */
if(g_sysExceptCallbak){
return 0;
1. As you can see in this function: /* TODO: some information stored in NV */ - will this TODO be ever done?
2. What is line in T_evtExcept[0] = line?
If I do something like this:
_attribute_data_retention_ u16 T_debug_except_code;
_attribute_data_retention_ u16 T_debug_except_line;
static void PowerBrdtSysException(void){
T_debug_except_line = T_evtExcept[0];
SYSTEM_RESET();
// while(1)
3. Will the values in T_debug_except_line and T_debug_except_code be saved or will they be cleared after SYSTEM_RESET()?
1、the TODO need you to implement.
2、the line is the location of the exception code
