Hello.
The ambient temperature sensor must be used.
This temperature sensor must be controlled by 1-wire communication.
Is it possible to capture using GPIO in TLSR825x?
If possible, I'd like to get an example source.
The temperature sensor is the model below.
You need to write your own code for the digital temperature sensor,no available sample code.
@Soyo
My question is. Is it possible to capture the TLSR825x GPIO?
If possible, is there a sample code?
Do you mean you need capture the single wire's communication signal? you can try use gpio interrupt demo(http://wiki.telink-semi.cn/tools_and_sdk/Driver/telink_b85m_driver_sdk.zip) to achieve by yourself,no sample code from us.
@wooseok
@Soyo
@wooseok
You will find plenty of examples for different devices if you google it "ds18b20 example c".
One example - https://github.com/jrmcguire/DS18B20/blob/master/example.c
You just have to modify to suit TLSR8258 - which shouldn't be too hard.
