I am using modified sampleLight example. I am using TLSR8258.
To the example I have added another light endpoint - so I have to endpoints 1 and 2.
I have modified the simpleSwitch example to add another endpoint as well.
So I can turn On/Off each of the light with buttons on "simpleSwitch".
The question is, how to save/restore the status of each of the lights?
There is a function to save attribute nv_sts_t zcl_onOffAttr_save(void), which uses the following function to read saved data:
st = nv_flashReadNew(1, NV_MODULE_ZCL, NV_ITEM_ZCL_ON_OFF, sizeof(zcl_nv_onOff_t), (u8*)&zcl_nv_onOff);
And to save data:
st = nv_flashWriteNew(1, NV_MODULE_ZCL, NV_ITEM_ZCL_ON_OFF, sizeof(zcl_nv_onOff_t), (u8*)&zcl_nv_onOff);
I have g_zcl_onOffAttrs1 for light number 1 and g_zcl_onOffAttrs2 for light number 2.
I can't see anything in those function that would allow me to save status for both lights.
So, how can I save/restore the status of both lights?
Should I add another item (for example NV_ITEM_ZCL_ON_OFF2) to typedef enum{{ }nv_item_t in drv_nv.h?
You can add new another Item as you said,and you also can save 2 endpionts' onoff1 ,onoff2 data into one buffer,then save to one Item,like below example.
u8 data[4];
data[0] = onoff_1;
data[2] = onoff_2;
st =nv_flashWriteNew(1, NV_MODULE_ZCL, NV_ITEM_ZCL_ON_OFF, sizeof(data), (u8*)data);
Hi Soyo,
Thanks for your help.
Your solution seems better.
