Hi everyone! Is there a guide where telink explain how to create a project for TLSR8359 and one (or more) explained/commented sample code? I can find practically nothing on google.
I've already installed the SDK and the IDE but I can't find any examples in telink IDE to understand how to code. I found just a guide about the IDE but it's not so useful since I'm able to create a new file and to press "compile all".
I don't know which is the structure and which are the instructions in C to code TLSR8359. I also don't understand why Telink IDE doesn't find stdio.h and stdlib.h since I have MingW GCC installed on my pc. I'm running Windows 7 on my pc for better compatibilty (the IDE is quite old).
Thanks for help!
Hi Mattia,
1、This document(http://wiki.telink-semi.cn/doc/an/AN_16063000-E1_Guide%20For%20Adding%20New%20Project%20On%20Existing%20SDK.pdf) can guide you to create a project from an extend sdk
2、you can browse http://wiki.telink-semi.cn/wiki/chip-series/TLSR835x-Series/ to get sample Project
3、The IDE dont need third-party like MingW,and you should install IDE in the default path,then software dependencies are automatically installed
My email is mattia@v-research.it.
Thank you!
I follow the steps in pdf, but after I refresh the SDK, the new project doesn't appear in "vendor"
