Hi Responsible,
I would like to know which the debugging tool for ELF files on Telink IDE (wtih breakpoint and steep-by-steep execution options).
Could you please share the installation / configuration procedure for it Debugger function?
Best regards
Leandro Santos
Our tool can't support break-point and step-by-step execution mode, you can use tdebug( which can be opened by wtcdb) to observe the variable value and other information. And can use the wtcdb to check the value of RAM , register, flash and so on. You can reference the related docs in debug tool files.
Your products seem promising but the lack of effective debugging can be a no-go ! Do you plan to support full debugging (break points, step-by-step, watches), for instance in Eclipse ?
Best regards
Any updates on the debug tools?
Is there any internal tool, even if expansive (Synopsys, Cadence), that could do breakpoint?
Also, is there any tools for unity testing?
Best regards
Any news on debugging tools?
Is it technically possible to have these debug features (IC supports it) if we happen to invest in developing a compatible debugger software?
We really will need debug and automated testing capabilities to implement complex applications using this IC, anything that could help on that is appreciated.
Best regards
