TLSR825x
Is there an emulated API function that covers all user areas related to "flashwrite"?
For example, if a user writes 5byte to 0x7D000, the next time they write, it is automatically written from 0x7D006.
I'm only using the same "Address" continuously, and I'm worried that if I use the same number continuously, the life of that "address" will be shorter than other unused "address", resulting in problems.
you need manage flash by yourself,if you write same address ,you need erase before write,and you can use some of third party flash's management algorithms,
