Hi~.
Use the function mini_print in "telink_mesh_sdk".
I checked that it is defined in the printf.c file in the "proj/common" folder.
But I think this function is designed in an nDMA method.
Can I change this to the DMA method?
The mini_print serial port that uses the pin emulation,not hardware serial port,if you need dma ,pls download driver SDK,and find uart demo.
