I want to debug Telink 8258 with USB Print. but, I can't files introduction. And I can not find driver for board Telink 8258 doggle .Please help me. Thank you very much!!!
Which SDK are you using,driver SDK/zigbee SDK or BLE SDK?
1, set USB_PRINT_MODE to enable printf function;
2, invoke usb_set_pin_en() and usbhw_set_printer_threshold(1) to initialize USB printer mode;
3, connect the USB port of the dongle directly to the PC, and open the BDT tool;
4, change the connect mode to USB;
5, select the "Log windows";
6, set ASCII display mode. "View->usb log->ASCII".
When I connect board Telink 8258. I don't have driver for Telink 8258
same problem with me, has this got the answer?
until now i still can t solve this problem, I'm using the sdk driver (Debug Demo)
problem solved. to view the windows log, the MCU board must be directly connected to the PC without going through the burning board.
thank you
problem solved.
thank you
