Dear all,
I have a done development from 3 years ago. Havng to restructure something, I wanted to programm my TLSR8266 via the C1T42A20 EVK daugtherboard as I did before.
After some few steps, the daughterboard was no more recognized by MS Win11 as USB decive.
Same with a second daughterboard.
I can not directly work with this boards anymore and so, I do not have a chance to programm my devices.
At this point I tried to press the button on the daughterboard while attaching it to the pc.
With this procedure the device is recognized as USB printer and I can access it with for example wtcdb.
So I think, I'm in a kind of bootloader that way.
And I think I have damaged the standard firmware for normal booting and programming.
If this is correct:
1) Where can I find the original firmware for using the EVK daugtherboard
2) How can I burn it, to have my evk daughter boards working normally again
Any help or ideas appreciated. Thank you.
Regards,
Frank
This EVK downloader is no longer maintained. Please purchase a new EVK downloader for use.http://wiki.telink-semi.cn/wiki/IDE-and-Tools/Burning-and-Debugging-Tools-for-all-Series/
Thank you. I already have such a device. This means it is capable of programming the TLSR8266 as well?
Regards,
Frank
@TL_Soyo
Yes, It support all chips.
@frank.schuetz
Regards,
Frank
@TL_Soyo
@frank.schuetz
