Hello,
We are having an application that uses UART0 for other MCU communication and UART1 for sensor communication.
With Chip TLRS9218A can we use 2 channels UART0 and UART1 for above application?
I'm getting the MCU reboot error when using both UART0 and UART1.
Developer Handbook for TLSR9 |
TLSR9 不能擦除flash |
BLE and Thread for B91 |
ESB mode on TLSR9 B1 |
关于断点调试 |
IDE License for TLSR9 Chips |
Zigbee RF 收发包测试 |
关于9218作为主连接外设 |
No more topics |
it can use both of them at same time,visit wiki and download driver SDK http://wiki.telink-semi.cn/wiki/chip-series/TLSR921x-Series/,when driver SDK port ok,then port to Zigbee SDK.
I wrote more for uart1 . handler
But I can't use both UART0 for MCU another and UART1 for Sensor
@TL_Soyo
please do not use zigbee SDK api to init two of uart,you should start with driver SDK http://wiki.telink-semi.cn/wiki/chip-series/TLSR921x-Series/,when driver SDK port ok,then port to Zigbee SDK.
@TrungNT
I have consulted the SDK driver section but it is the same as Zigbee's SDK
Currently, I can only use 1 UART.
I have to SWITCH between UART0 and UART1 for my application
@TL_Soyo
You can use both of two uart for you application,try use driver SDK to port you appliction frist.
Hello,
I am using TLSR9218A for Zigbee, Can you provide me with sample source code for using UART0 and UART1?
@TL_Soyo
Hello,
I can't use UART0 and UART1 at the same time right?
That means I will have to switch 2 channels UART0 and UART1 to use alternately, right?
@TL_Soyo
@TrungNT
@TL_Soyo
