When I run "zb_rejoinReq(channel_mask, 3)" for sending "rejoin request" message to coordinator,
It can not send "rejoin request" message to coordinator.
How to send "rejoin request" message to coordinator ?
what status of the device when send zb_rejoinReq,also you can print the zb_rejoinReq return code to check what happened.
Can you explain sequence when "zdo rejoin request" message is sent ?
@TL_Soyo
When this device is joined on A network, I want to change channel and extended id to B network and rejoin to B network.
Thus I ran zb_rejoinReq() to B network.
status of zb_rejoinReq() is 128 (0x80, ZDO_INVALID_REQUEST)
@ TL_Soyo
status of zb_rejoinReq() is ZDO_INVALID_REQUEST
@JaeYong Lee
Does the device has not been joined the network before? this cmd need device joined network before
you can do factory set then do direct join process to join network B,or you cannt join new network.
@TL_Soyo
@TL_Soyo
@TL_Soyo
@TL_Soyo
@TL_Soyo
@TL_Soyo
@ TL_Soyo
@JaeYong Lee
@TL_Soyo
