Where can I find the source for the objects shipped as the three (end device, router, gateway/coordinator) object archives e.g. `tl_zigbee_sdk\zigbee\lib\tc32\libzb_coordinator.a`? I believe that your use of GNU code requires that such code be made available when requested.
I want the source code because I have a project that requires my Zigbee device to switch between coordinator and end device roles and I would like to create a "common library" that has both coordinator and end device (and perhaps router) functionality but with the active type (my device only fulfills one roles at a time) being determined by a config function. I don't want to have to link in (with lots of name hiding to avoid clashes) multiple instances of the libraries, if only because of the size issues!
Thanks,
Paul DS (papadeltasierra).
P.S. Obviously happy to share any resulting code with you in case it is useful to others.
