There are two methods to connect the target board with the burning EVK, USB and SWS. It is recommand to use sws method, for the reason that many projects in sdks have lower-power function. Mcu will enter lower-power mode when it is idle. so the burning Evk cannot reset the target board`s mcu when using usb method.
if fails to reset mcu via sws method, please try following solutions to recover the board with these problems.
one way:Cut off the power of burning EVK, connect the DUT to burning EVK, use a tool or a wire to short the two point of the capacitance in PIN VDDEC , then connect the burning EVK to PC, release the short wire of the capacitance. Now you should be able to reset the DUT.
second way:sometimes you can connect GND(DUT) to GND(burning EVK), SWS(DUT) to (burning EVK), then reset mcu by wtcdb, if worked, connect the VCC wire, you will operate as usual later.
[code]make all //编译 make erase_fw //擦除固件 make erase_key //擦除Mesh相关数据 make monitor //打开串口监控 python3 ../../make/Telink_Tools.py -p /dev/ttyUSB0 burn_triad 1345 78da07fa44a7 221746e805ac0e6269bd4d3e55f1145c //烧录三元组 python3 ../../make/Telink_Tools.py -p /dev/ttyUSB0 write_flash 0x30000 235798abdfc //写Flash python3 ../../make/Telink_Tools.py -p /dev/ttyUSB0 read_flash 0x30000 256 //读Flash
