Hello there, hope you doing good.
I am planning on porting an existing proprietary stack on to TLSR8208/8366. The frame format for the same is as under:
Preamble | Access Code | Length | Payload
(1-4B) | (4B) | (1B) | (32B min.)
I was looking at the Gen FSK LL, the code samples and document. The document mentions that header is 9 bit, out of which the 6bit is the address. But it is mentioned as negligible for Generic FSK.
So I am here to clarify, does that mean the those bits are not transmitted over the air, or those bits are not set altogether?
To maintain the on air compatibility with existing, I have to ensure that the on air format remains the same so it can successfully recieve and transmit in given format.
Thanks for reading, looking forward for any inputs.
No more topics |
