I use the TLSR8278 kit to make AOD.
My system consists of two transmitters (made up of 8 antennas each) and one receiver(with one antenna). I use the RF_AOA_DEMO demo provided by Telink. Departure and elevation angles are displayed via the UART.
I made a difference between the two packets sent by the transmitters so that the receiver can know which signal is received:
emitter1(200 ms)
emiiter (250ms)
Receiver:
The problem is that the two signals overlap and therefore the angle values are not good. how can I solve this problem?
How to debug TLS8278 with eclipse or BDT CONNECT |
HI,
suggest using MAC addresses for differentiation,
