I'm used buetooth mesh sdk, the charaters of DEV_NAME limited to a maximum of 9 characters. so how to increase the number of characters of DEV_NAME? thanks very much.
When I enable define USER_REDEFINE_SCAN_RSP_EN and AIS_ENABLE to 1. I received the adv name of my device is Telink Remote. But i can not found the define Telink Remote in the sdk.
DEV_NAME limited to MAX_DEV_NAME_LEN,and fixed 18 in libs,user can not change,if you enable USER_REDEFINE_SCAN_RSP_EN,please call bls_ll_setScanRspData() set you rsp data.
thank you for your reply.
I change my code as below but it's not worked. Where is call the bls_ll_setScanRspData() function? thank's very much.
you need fowllow the ble ADV format to set buffer.
