Hello everyone, I am trying to build Thread -Matter device. During the product benchmarking process, we encountered the following scenarios:
1. A Thread device operating in an environment with many Zigbee devices experienced limited range and stability. However, when I moved the Thread device away from that area, it started working normally again.
2. : This is the result when I run the benchmark in both the Zigbee network space and without the Zigbee network.
If possible, I hope you can help me come up with ideas to fix this issue.
Thank you, everyone!!!
They have same 802.15.4 MAC layer,so it will affect each other.
Thanks TL_Soyo. While trying to address this issue, I attempted to scan the channels of the thread using chiptool (from channel 11 to channel 26), and here are the results:
Is there any issue with the automatic channel selection of the Thread network? I wonder if the reason for channel selection is related to the configuration of my device or if it's only relevant to the border router. I would greatly appreciate it if you could provide me with information regarding this matter
