During the update to OTA, "is_receive_ota_window()" should be true and the main loop statement should not be turned around, but the update test is currently conducted with APP, and "is_receive_ota_window()" continues to be false, causing the main loop statement to fail from time to time.
What command should the APP give to make "is_receive_ota_window()" true? Or how can I make it true?
What‘s problem now,does the function return false when you process OTA.
@TL_Soyo
@TL_Soyo
