Hello.
With patches\patch_v3670-v3674
I make sampleSensor
Building file: C:/Users/Olga/eclipse-workspace-telink-ide/SDK/tl_zigbee_sdk/zigbee/zcl/zll_commissioning/zcl_zll_commissioning.c Invoking: TC32 Compiler tc32-elf-gcc -ffunction-sections -fdata-sections -I../../../apps/common -I../../../apps/sampleContactSensor -I../../../platform -I../../../proj/common -I../../../proj -I../../../zigbee/common/includes -I../../../zigbee/zbapi -I../../../zigbee/bdb/includes -I../../../zigbee/zcl -I../../../zigbee/ota -I../../../zbhci -DEND_DEVICE=1 -DMCU_CORE_8258=1 -D__PROJECT_TL_CONTACT_SENSOR__=1 -Wall -O2 -fpack-struct -fshort-enums -finline-small-functions -std=gnu99 -fshort-wchar -fms-extensions -c -o"zigbee/zcl/zll_commissioning/zcl_zll_commissioning.o" "C:/Users/Olga/eclipse-workspace-telink-ide/SDK/tl_zigbee_sdk/zigbee/zcl/zll_commissioning/zcl_zll_commissioning.c" C:/Users/Olga/eclipse-workspace-telink-ide/SDK/tl_zigbee_sdk/zigbee/zcl/zll_commissioning/zcl_zll_commissioning.c:62:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'g_nwkTouchlinkCb' make: *** [zigbee/zcl/zll_commissioning/zcl_zll_commissioning.o] Error 1
Without patch is ok.
make --no-print-directory post-build
"../../../tools/tl_check_fw.sh" sampleContactSensor_8258 tc32
this is post build!! current configure is :sampleContactSensor_8258
copy from `sampleContactSensor_8258.elf' [elf32-littletc32] to `sampleContactSensor_8258.bin' [binary]
File size:125748
output done!
**************** end of post build ******************
Invoking: TC32 Create Extended Listing
tc32-elf-objdump -x -D -l -S sampleContactSensor_8258.elf >"sampleContactSensor_8258.lst"
Invoking: Print Size
tc32-elf-size -t sampleContactSensor_8258.elf
text data bss dec hex filename
125296 448 12536 138280 21c28 sampleContactSensor_8258.elf
125296 448 12536 138280 21c28 (TOTALS)
Finished building: sizedummy
Finished building: sampleContactSensor_8258.lst
the patch is used for v3.6.7.0-v3.6.7.4 SDK,the latest SDK wont need the patch.
