Hi everyone,
I use TLSR8251 chip. I want to use ADC modul to period read voltage on pin PB2.
I chose the misc channel.
Max state = 2, r_max_s = 10, r_max_mc = 240, sampling = 6 cycle. Fadc = 4MHz, Ttotad duration = 10,417us => Fs = 96kHz
I found some difference between documentation and driver.
Documentation:
ADC data is always 15-bit format no matter what the resolution is set. For example, 14 bits
resolution indicates ADC data consists of 14-bit valid data and 1-bit sign extension bit.
Driver:
if(adc_data_buf[i] & BIT(13)){ //14 bit resolution, BIT(13) is sign bit, 1 means negative voltage in differential_mode
adc_sample[i] = 0;
else{
adc_sample[i] = ((unsigned short)adc_data_buf[i] & 0x1FFF); //BIT(12..0) is valid adc result
Which one is correct?
I have some questions.
1. Why in driver we wait minimum 2 sample cycles? while(!clock_time_exceed(t0, 25)); //wait at least 2 sample cycle(f = 96K, T = 10.4us)
In documentation we can read that after "Caputre state" data is ready. It looks like 1 sample cycle is enough. Am I right?
2. Case: FIFO disable. Will the ADC module automatically go to the "Set state" after the "Capture state" will be completed? Or will it wait to result read?
3. Case: FIFO enable. Question as above. Will the ADC modul automatically go to write new value to FIFO buffer after it reaches FIFO size?
4. Does conversion take 6 cycle (in my settings) in Capture State or more?
Thank you for your answers.
Best regards,
Krzysztof
Documentation and driver all are right,we only use 14-bit valid data that contain BIT(12..0) valid adc,BIT(13) sign bit;
1、adc need 20.8us to do one sample
2、diable fifo ,you need control by yourself,please refrence adc_sample_and_get_result_manual_mode();fuction ,control the register "adc_data_sample_control"
3、ADC automatically go to write new value to FIFO buffer index 0 position agian
4、please calculate by yourself though the above table
Which documentations do you have? In my version: Ver 0.8.10 2023/2/16 for TLSR8251 have:
afe_0xf3<7:0> - Reserved.
Best regards,
Krzysztof
you can download Tlsr8278 datasheet find it,but the two of chips many characteristics are different.
