I have installed latest SDK v.6.8.2 and noticed that in drv_hw.c in function drv_platform_init() there is now the following code:
if(flash_is_zb()){
#if (!VOLTAGE_DETECT_ENABLE) || !defined(VOLTAGE_DETECT_ENABLE)
voltage_detect_init(VOLTAGE_DETECT_ADC_PIN);
flash_safe_voltage_set(BATTERY_SAFETY_THRESHOLD);
#endif
flash_unlock_mid13325e(); //add it for the flash which sr is expired
In one of my projects I have used all pins and don't have any pin that can be used as VOLTAGE_DETECT_ADC_PIN.
I am not sure what zb flash is?
Could you please explain what zb flash is?
if your chip is using ZB's internal Flash,the code will set the safe writing flash voltage THRESHOLD,Don't worry if you don't use low power.
