I have a problem with flashing:
* Executing task: ./ICEman -Z v5
Andes ICEman v4.6.3 (OpenOCD) BUILD_ID: 2020090411
Burner listens on 2354
Telnet port: 4444
TCL port: 6666
Open On-Chip Debugger 0.10.0+dev-g01d57cb (2020-09-04-11:43)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Andes AICE-MINI+
JTAG frequency 10.000 MHz
There is 1 core in tap
The core #0 listens on 1111.
ICEman is ready to use.
* Executing task: ./SPI_burn -i ./../../../app/build/apptest.bin -v
image_filename: ./../../../app/build/apptest.bin
NDS32 Burner BUILD_ID: 2020042409
Attempting to connect to 127.0.0.1, port 2354
Failed to find SMU ID
How to fix this behavior? Can I flash my firmwarevia J-Link?
Developer Handbook for TLSR9 |
TLSR9 不能擦除flash |
BLE and Thread for B91 |
ESB mode on TLSR9 B1 |
关于断点调试 |
IDE License for TLSR9 Chips |
Zigbee RF 收发包测试 |
关于9218作为主连接外设 |
No more topics |
HI,
Please fowllows the steps.
AndeSight IDE
Make sure the AndeSight IDE is already correctly installed on your PC.
Flashing
We are going to use the example program above to illustrate how to flash a binary file to an Eagle EVK.
Make sure the Telink debug probe is connected to the Eagle EVK correctly and the EVK is already powered.
Launch a Cygwin shell.
Navigate to the ice folder in which the ICEman tool is installed (e.g. C:\Andestech\AndeSight_RDS_v320\ice).
Run the following command.
Launch another Cygwin shell and navigate to the ice folder in which the SPI Burn tool is located (e.g. C:\Andestech\AndeSight_RDS_v320\flash).
Type the following command.
Note: the -i option specifies the binary file that will be programmed into the Eagle EVK and the -v option enables verification after flashing.
My host system is Ubuntu 22.04.
BTW it's fixed by myself: Last time when I worked with Telink I used https://github.com/andestech/Andes-Development-Kit/releases/tag/ast-v3_2_3-release-linux ICE and Burning tool. But now it doesn't working and failed as I show before. But with http://wiki.telink-semi.cn/tools_and_sdk/Tools/IDE/telink_riscv_linux_toolchain.zip it works ok
Also could you please help to setup debug in VSCode?
Done by myself too. GDB from Telink package doesn't work with debug extensions. Fixed by https://github.com/andestech/Andes-Development-Kit/releases/download/ast-v3_2_3-release-linux/nds32le-elf-mculib-v5f.txz
