Hello ~.
I m studying with "Telink mesh sdk". http://wiki.telink-semi.cn/wiki/protocols/Telink-Mesh/
I purchased the development kit from the link above.
And I checked that I can turn on and off several lights with my smartphone and remote control (PCB with buttons).
I have a question.
This is the environment I tested.
- 3 light modules
- Two smartphones (one for mobile and one for wall pad)
- 1 remote control (for those without a smartphone or wall pad)
It worked perfectly.
In the test environment above, I would like to add one more remote control, is there any way?
It doesn t matter if you reduce your smartphone to one.
In fact, I don t use a wall pad.
In other words, is there a way to change it to the environment below?
- 3 light modules (may be more than this)
- 1 smartphone
- 2 remote controls (for those without smartphones or wallpads)
just add more remote control,remote control works as a mesh node,so more remote control is fine.
thank you reply soyo ^^
