I spent a lot of time trying to figure it out.
As per my previous post I use sampleLight modified example.
I add the second endpoint to control second light
I defined 2 endpoints:
#define LIGHT_ENDPOINT1 0x01
#define LIGHT_ENDPOINT2 0x02
I define OnOff Attributes:
zcl_onOffAttr_t g_zcl_onOffAttrs1;
zcl_onOffAttr_t g_zcl_onOffAttrs2;
and
const zclAttrInfo_t onOff_attrTbl1[]
const zclAttrInfo_t onOff_attrTbl2[]
Function user_init() has the following calls:
/* Initialize user application */
user_app_init();
/* Register except handler for test */
sys_exceptHandlerRegister(LightSysException);
/* Adjust light state to default attributes*/
light_adjust();
In user_app_init() I have:
/* Register endPoint */
af_endpointRegister(LIGHT_ENDPOINT1, (af_simple_descriptor_t *)&Light_simpleDesc1, zcl_rx_handler, NULL);
af_endpointRegister(LIGHT_ENDPOINT2, (af_simple_descriptor_t *)&Light_simpleDesc2, zcl_rx_handler, NULL);
/* Initialize or restore attributes, this must before zcl_register() */
zcl_LightAttrsInit();
zcl_reportingTabInit();
/* Register ZCL specific cluster information */
zcl_register(LIGHT_ENDPOINT1, LIGHT_CB_CLUSTER_NUM, (zcl_specClusterInfo_t *)g_LightClusterList);
zcl_register(LIGHT_ENDPOINT2, LIGHT_CB_CLUSTER_NUM, (zcl_specClusterInfo_t *)g_LightClusterList);
In zcl_LightAttrsInit(), there is a call to function zcl_onOffAttr_restore();
Attributes for both lights are restored correctly.
But after the call to: light_adjust();, I can see that the attribute for light 1 is lost - OnOff attribute is always 1 (ON).
After a lot of time, I found out that the attribute is lost (changed to 1) after the first call:
When I changed and put zcl_LightAttrsInit();
after both calls to zcl_register(...), everything works fine.
Is it how I should be doing this?
So the question is why is it happening?
And this only happened for light 1, light 2 attribute was never lost?
Unless I was doing something wrong when registering 2 endpoints?
Hi Soyo,
Thanks for this information.
How about bdb_defaultReportingCfg(...) and bdb_init(...)?
Do I have to do it for each endpoint
bdb_defaultReportingCfg(LIGHT_ENDPOINT1, HA_PROFILE_ID, ZCL_CLUSTER_GEN_ON_OFF, ZCL_ATTRID_ONOFF, 0x0000, 0x003c, (u8 *)&reportableChange);
bdb_defaultReportingCfg(LIGHT_ENDPOINT2, HA_PROFILE_ID, ZCL_CLUSTER_GEN_ON_OFF, ZCL_ATTRID_ONOFF, 0x0000, 0x003c, (u8 *)&reportableChange);
/* Initialize BDB */
bdb_init((af_simple_descriptor_t *)&Light_simpleDesc1, &g_bdbCommissionSetting, &g_zbDemoBdbCb, 1);
bdb_init((af_simple_descriptor_t *)&Light_simpleDesc2, &g_bdbCommissionSetting, &g_zbDemoBdbCb, 1);
But this doesn't really explain why the restored attribute is changed after the call to zcl_register?
@wes58
bdb functions don't need call twice,it used to register net behavior,after call af_endpointRegister,new EP is built,and then implement your own zcl functions.
don't use same call back function : af_endpointRegister(LIGHT_ENDPOINT2, (af_simple_descriptor_t *)&Light_simpleDesc2, zcl_rx_handler_2, NULL);
You can search AF_TEST_ENABLE in ZIgbee SDK ,it is a demo to add a new EP.
Hi Soyo,
@wes58
Hi Soyo,
I still had doubts about zcl_register, so I looked in the SDK manual.
It reads:
The user registers the desired ports as well as clusters and attributes according to the specific product
features.
- Port registration:
af_endpoitRegister()
Register a port to specify the detailed function of the port (profileId, deviceId, port number, and supported
input clusters (server), output clusters (client).
- Cluster registration:
zcl_register()
Register the Clusters, Attributes related registration function and command callback processing functions
for a port.
So, I assume that "port" refers to the endpoint?
And in section 4.4.4.2 Data interaction using AF layer, it reads:
If not using zcl in sdk, there is no need to invoke zcl_register() and zcl_init().
Implementation method is as below.
1) Register the data reception processing callback function user_rx_handler and the send confirmation callback
function af_dataSentConfirm.
2) Invoke af_dataSend to send data.
Since in the SDK example, with AF_TEST_ENABLE, zcl is not used for SAMPLE_TEST_ENDPOINT, there is no need to use zcl_register() for this endpoint. In zb_afTestcb.c, af_dataSend() function is used - as described in section 4.4.4.2 in the SDK manual.
So I think that if I am using zcl for all endpoints, I have to use zcl_register() for all of them.
What do you think?
@wes58
AF_TEST_ENABLE it is a demo to add new EP,but no ZCL ,so you need add zcl functions for all of them,
Hi Wes58,
Do you try your device (with multiple Lights) to join to Philips Hue Bridge? Can the Philips Hue Application show/handle multiple Lights? I also add 2nd endpoint but Philips Hue application only shows a light! :((
I resolved!
