//carrier_en: must 1 or 0
static inline unsigned short pwm_config_dma_fifo_waveform(int carrier_en, Pwm0Pulse_SelectDef pulse, unsigned short pulse_num)
嗨,你可以和原始SDK代码对比检查。
@Soyo
另外对比过源码了,移植过来是一样的,看dma中定义的size是511bytes,按照pwm_config_dma_fifo_waveform中定义的buffer数据,可以在dma中存储255组,但是我实际输出pwm波形有效的只有30组,请问还缺少什么配置?盼复,谢谢!
//carrier_en: must 1 or 0 static inline unsigned short pwm_config_dma_fifo_waveform(int carrier_en, Pwm0Pulse_SelectDef pulse, unsigned short pulse_num)
{ return ( carrier_en<<15 | pulse | (pulse_num & 0x3fff) ); }
@Soyo
有关于FLD_DMA_PINGPONG_EN这几种机制的介绍文档或者demo的实现例子码?官网下载的datasheet没有看到相关的介绍
嗨,你可以和原始SDK代码对比检查。
@Soyo
@Soyo
你好,请对比参考和原始SDK的修改,以下为在原始SDK上重复波形输出的结果。
void user_init()
sleep_ms(2000);
pwm_set_clk(CLOCK_SYS_CLOCK_HZ, CLOCK_SYS_CLOCK_HZ);
gpio_set_func(PWM_PIN, AS_PWMx);
pwm_set_mode(PWM_ID, PWM_IR_DMA_FIFO_MODE);
pwm_set_cycle_and_duty(PWM_ID, IR_DMA_MAX_TICK, IR_DMA_CMP_TICK);
pwm_set_pwm0_shadow_cycle_and_duty(IR_DMA_SHADOW_MAX_TICK,IR_DMA_SHADOW_CMP_TICK);
unsignedchar index=2;
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(1, PWM0_PULSE_NORMAL, 9000 * CLOCK_SYS_CLOCK_1US/IR_DMA_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(0, PWM0_PULSE_NORMAL, 4500 * CLOCK_SYS_CLOCK_1US/IR_DMA_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(1, PWM0_PULSE_NORMAL, 560 * CLOCK_SYS_CLOCK_1US/IR_DMA_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(0, PWM0_PULSE_NORMAL, 560 * CLOCK_SYS_CLOCK_1US/IR_DMA_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(0, PWM0_PULSE_NORMAL, 1690 * CLOCK_SYS_CLOCK_1US/IR_DMA_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(1, PWM0_PULSE_SHADOW, 9000 * CLOCK_SYS_CLOCK_1US/IR_DMA_SHADOW_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(0, PWM0_PULSE_SHADOW, 4500 * CLOCK_SYS_CLOCK_1US/IR_DMA_SHADOW_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(1, PWM0_PULSE_SHADOW, 560 * CLOCK_SYS_CLOCK_1US/IR_DMA_SHADOW_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(0, PWM0_PULSE_SHADOW, 560 * CLOCK_SYS_CLOCK_1US/IR_DMA_SHADOW_MAX_TICK);
IR_DMA_Buff[index++]= pwm_config_dma_fifo_waveform(0, PWM0_PULSE_SHADOW, 1690 * CLOCK_SYS_CLOCK_1US/IR_DMA_SHADOW_MAX_TICK);
unsignedint length = index*2 - 4;//The first four bytes are data length bytes, not included in the actual length to be sent
unsignedchar* buff = &IR_DMA_Buff[0];
buff[0]= length&0xff;
buff[1]= (length>>8)&0xff;
buff[2]= (length>>16)&0xff;
buff[3]= (length>>24)&0xff;
pwm_set_dma_address(&IR_DMA_Buff);
pwm_set_interrupt_enable(PWM_IRQ_PWM0_IR_DMA_FIFO_DONE);
irq_set_mask(FLD_IRQ_SW_PWM_EN);
irq_enable();
pwm_start_dma_ir_sending();
@Soyo
感谢上面的解答,还有一个问题请教一下,当中断触发时,产生的波形是否是跟中断触发前的连续?还是中断触发后的波形会重新开始?
我这边用for循环来代替,输出一段波形后令index = 2,波形不会连续产生。
盼复,多谢!另外关于DMA 的pingpong机制有其他文档介绍嘛?
@Soyo
感谢解答,另外想请问一下,在demo例程里面,如果进入中断后,pwm波形是会接着中断前的继续输出,还是会重新开始新的一轮输出?从例程来看最大一次性只能输出255组数据,需要如何配置才能连续输出更多的数据大于255组,波形需要连续。
盼复,多谢!
进入中断代表fifo数据处理完成,还要继续输出需要在中断中重新载入一遍,参考例程的中断处理。
@Soyo
这个中断irq_handler怎么关联触发,想重新定义一个中断函数,不然irq_handler会重复定义。
