My Zigbee stack works normally for a while. After a period of time, it can t send data or receive data.
When sending data it callback error is 0x1D. I think this error is:
MAC_TX_ABORTED 0x1D.
I want to know why is this guilty.
Thank you.
NLME-NWK-STATUS.indication |
MAC_TX_ABORTED indicate Zigbee Tx handle error,usually it wont get this problem,u can compare original demo code and your code,and dont call send message function too quickly.
Hi Soyo.
My device works normally about 20 m to 10 h depending on the device. It can not send or received data. Does hardware affect the Zigbee stack? My code on board dongle is very good.
You can check the power supply,TX state need biger current,do you use battery as power supply
I use a power AC. But when Zigbee stack stopped working. Another driver works normally like PWM, I2C.
Try to check TX interrupt bitmask whether be set disable when your code is running ,and debug in Interrupt callback function to check whether other interrupts are always triggered.
