TLSR8255 - 48 MHz clock output
I'd like to know if it is possible to get a 48 MHz clock output at a GPIO pin in TLSR8255.
Checking the documentation, I see there is a doubler from the 24 MHz clock to 48 MHz and that there is a USB_clk and a way to get 48 MHz to FHS, but I coudn't tell if there is a way to get that signal in a GPIO pin.
The objective is to provide the 48 MHz clock to an external Sub-GHz transceiver.
Best regards,
Camilo Rodegheri
DEV Tecnologia
According to your description below, you are expecting a clock signal output from a GPIO pin?
If that is the case , that will be a feature not supported.
it is possible to have a clock source input into a telink MCU, and double it to 2x, 4x,...to the target clock speed
then (and divide it if necessary )render it to USB,DMIC, system clk, system timer clk...
but not a way out for output to a IO pin and then render it to other peripheral .
In your case , for example , if need a 48Mhz clock to drive an external Sub-GHz transceiver, looks like you will some external OSC, or use internal OSC/RC come with the Sub-GHz transceiver SOC.
FYI
Kidd
FAE
