I tried to follow procedure described here:
http://wiki.telink-semi.cn/wiki/IDE-and-Tools/Compiler_Linux/
I applied this on Driver SDK 2.0.0 referenced here: http://wiki.telink-semi.cn/wiki/chip-series/TLSR9-Series/
I m using toolchain: http://wiki.telink-semi.cn/tools_and_sdk/Tools/IDE/telink_riscv_linux_toolchain.zipThe CMakeLists.txt has to be modified because some directories where moved (drivers/B91 -> /chip/B91/drivers; vendor -> demo/vendor; etc...)
some changes in files name also:
${CMAKE_CURRENT_LIST_DIR}/chip/B91/boot/cstartup_flash.S)
After that I still have compile errors.
error shows libncurses.so.5 is expected to be present in: telink_riscv_linux_toolchain/nds32le-elf-mculib-v5f/riscv32-elf/bin/ld
But this directory is empty
The apps note is not in line with latest deliveries. Would it be possible to have consistent references to sources and build method for reference example with Linux (don t want to go through window as much as possible)?
ESB Enhanced ShockBurst support on TLSR9 B91 |
Hi jneanne,
There is a script that will install these for you in the AndesSight folder, it is install_package.sh or something similar.
Hi TL_bloom5,
Could you point me to a link where I can download this?
