Hello, I'm developing a BLE central device with tlsr8251. In scan test I always get the normal advertisement, but almost never get the scan_response packages, just in some random times appears some data. I've already enabled Scanning through blc_llms_setScanEnable to clear the scan response list, but only in rare moments can I get the data from this response. Could you help me with this?
Hi Filipe,
Which scan type are you enabling, passive or active?
Hi, The type is active.
Hi Filipe,
You can use an externed API blt_llms_clearScanRspDevice() to clean the scan response list when receiving a ScanRsp packet. Here is reference code:
BTW, The original scan logic seems a bit slow just for power saving.
