Hello,
1. In function blc_ll_createConnection I can not set conn_intervals more than 300 ms (value is 256), but I would like to set about 1 s. In single conn SDK I can set such intervals.
2. It seems that there is no any realisation to answer on slave conn param update req, isn't it?
Thank you for any answer in advance.
Where to find Apple notification center service (ANCS) example for tlsr825x chip? |
1. In version 4.0.1.1, the master role support a maximum connection interval of 320ms.
2. You can register the event 'GAP_EVT_MASK_L2CAP_CONN_PARAM_UPDATE_REQ'. If slave conn param update req occur, then respond in app_host_event_callback().
